Hi all,
I am working with mashup responsive (advanced) and I wanna add a FieldSet in this mashup.
But always when I added this FieldSet it stay with Scrollbar. I already try every configuration of widget but I could not do this.
Leonardo
Hi @einsfele.
Have you checked out this information from the ThingWorx Help Center? Note there is a video that may provide some ideas.
If you still have questions, please provide the version of ThingWorx and your mashup, so we can test it here. Also, have you tested it in different browsers to see if the behavior is the same?
Regards.
--Sharon
Hi @einsfele.
Regards.
--Sharon
Hi @einsfele.
If the previous response allowed you to find a solution, please mark it as the Accepted Solution for the benefit of others on the community.
Regards.
--Sharon
