The community will undergo maintenance on October 16th at 10:00 PM PDT and will be unavailable for up to one hour.
Hello all,
I want to create 'Tags' available in Kepware(Thingworx Industrial Connectivity) as 'Property' in Thing using service.
Velkumar R
You can find some snippet code in this article : https://www.ptc.com/en/support/article?n=CS276903
Stéphane
You can use KEPServerEXExtension from thingworx marketplace and use AddItems service to add a tag as thing property .
Thanks ,
Mukul Narang
Stéphane
