How to create XML from a virtual thing object ?
ptc-89213
We have seen documentation to create thing in Thingworx server manually or to import XML definition of existing thing (already exported from same or another thingworx server).
We have a different problem at hand. We need to create things programatically using JAVA APIs.
I need to create XML for thing definition, which can be imported in Thingworx server. Are there any helper APIs which provide a way to dump XML for Thing object defined using VirtualThing class in java ?
Any thoughts on approach will be helpful ?
paic
(To:ptc-89213)
Can you describe the use case?
