The device I need to connect sents out its data via TCP socket request, not websocket request. My idea is to use PAT to get the data. PAT supports websocket by default, I can wrap the tcp packet as websocket request ( or any other channel PAT supports ) then sent it to PAT, but the more straightforward way is to create a custom Channel in PAT I think.
But I don't know how to register a custom Channel and how to config it in connector.conf . Is there a guide for creating custom channel ?
Sean
Hello Sean,
Thanks for reaching out on the ThingWorx Developer Community.
Looking into this there is a section of the ThingWorx Protocol Adapter Toolkit Developer's Guide which describes the creation of a custom channel. Please refer to the "Developing a Custom Channel" section on Page 46 of the guide.
Hopefully this gets you started with what you're looking for.
Tyler Misner
ThingWorx Technical Support Engineer
Hello Sean,
Tyler Misner
