Similar to the windchill
Based on the advanced query function of attribute selection
Hi Mr. Liang,
Here is my sample code:
var query1 =
"filters": {
"type": "GT",
"fieldName": "num",
"value": "12"}
var values = me.CreateValues();
values.num = num; //NUMBER
values.name = name; //STRING [Primary Key]
var params = {
maxItems: 500 /* NUMBER */,
values: values /* INFOTABLE*/,
query: query1 /* QUERY */,
source: undefined /* STRING */,
tags: undefined /* TAGS */
var result = me.QueryDataTableEntries(params);
For detail query infomation, please check here PTC.
And the values is what exectly you want to filter your datatable.
If you are using a InfoTable, and cannot use API QueryDataTableEntities, please follow below code:
var params = {
var myInfo = me.GetDataTableEntries(params);
var query1 =
"filters": {
"type": "and",
"filters":[
"type":"EQ",
"fieldName":"num",
"value":num
"type":"EQ",
"fieldName":"name",
"value":name
var params = {
t: myInfo /* INFOTABLE */,
// result: INFOTABLE
var result = Resources["InfoTableFunctions"].Query(params);
And the binding is like below screenshot:
Lily
Hi Mr. Liang,
I will do a sample for you soon.
Lily
hi,Mrs Lily
Myquery service Defined inside the thingtemplate?
Hi Mr. Liang,
Just follow below sample:
var query1 =
"filters": {
"type": "and",
"filters":[
"type":"EQ",
"fieldName":"num",
"value":num
"type":"EQ",
"fieldName":"name",
"value":name
var params = {
oldestFirst: undefined /* BOOLEAN */,
maxItems: undefined /* NUMBER */,
endDate: undefined /* DATETIME */,
startDate: undefined /* DATETIME */
var result = Things["ThingName"].QueryPropertyHistory(params);
Any concern, just feel free to let me know.
Hi Mr. Liang,
var query1 =
"filters": {
"type": "GT",
"fieldName": "num",
"value": "12"}
var params = {
var params = {
var query1 =
"filters": {
"type": "and",
"filters":[
"type":"EQ",
"fieldName":"num",
"value":num
"type":"EQ",
"fieldName":"name",
"value":name
var params = {
Lily
very detailed, thank you very much!
