How to customize Software Content Management Utility
IPA
11-Garnet
11-Garnet
I would like to customize the Software Content Management utility. Is there any documentation describing how this can be done?
E.g. I would like to edit some of the standard mashups of the SCM and create custom ones.
tmousaw
6-Contributor
(To:IPA)
I'd like to understand more about your particular needs.  Could you describe what functionality you desire that is not provided by the existing SCM mashups?
IPA
11-Garnet
11-Garnet
(To:tmousaw)
let me give you two examples:
Use Case 1:
Let's say I want to remove the options Deployments -> Track, Compliance -> Purge from the left sidebar menu (see screenshot). I also want to rename Packages -> PUBLISH to RELEASE.
Use Case 2:
In Package -> Create package, I need a new property "Region" for the package. Each package should be associated with a region.
Is it possible to customize the Software Content Management Utility? If yes, is there a document guide explaining how to customize it?
