I would like to customize the Software Content Management utility. Is there any documentation describing how this can be done?
E.g. I would like to edit some of the standard mashups of the SCM and create custom ones.
I'd like to understand more about your particular needs. Could you describe what functionality you desire that is not provided by the existing SCM mashups?
let me give you two examples:
Use Case 1:
Let's say I want to remove the options Deployments -> Track, Compliance -> Purge from the left sidebar menu (see screenshot). I also want to rename Packages -> PUBLISH to RELEASE.
Use Case 2:
In Package -> Create package, I need a new property "Region" for the package. Each package should be associated with a region.
Is it possible to customize the Software Content Management Utility? If yes, is there a document guide explaining how to customize it?
