My question is in the title !
I've been using REST Api in order to delete a specific entity, but I need to delete a group of things with the same tag, so how could I do that?
Thanks in advance!
Hi Elie,
The best way to do this is to create a custom service that you call from the REST Api and pass in the value of the tag (this can be a string value in the rest call). You can convert this to a tag in the service, then search for things with that tag using the SearchThings service in the SearchFunctions resource. Loop through the resulting infotable and delete the things.
Adam
Hi Elie,
Adam
That is actually a really good idea! I'm not sure that this was what I was looking for but it should really help me anyways.
Thank you!
