Using deleted table property and doubleclick trigger event,how to delete a row in advanced grid in version 8.5
Hi @gajapriya.
Which version of 8.5 are you running? This issue was a defect that was corrected in ThingWorx 8.5.4.
--Sharon
I've never used the DeletedTable, but using either that? or SelectedRow(s)
you'd pass that into a service and then with that service you'd located and remove those rows from the actual source.
Hi @gajapriya.
--Sharon
