I have a field with a values for example
worker
worker
manager
manager
and I want to delete those duplciates so the result in field will be
worker
manager
Hi Aleksandar,
What exactly is your requirement?
If you want to just display unique rows out of an Infotable,you can use below Distinct Snippet.
var params = {
t: undefined /* INFOTABLE */,
columns: undefined /* STRING */
// result: INFOTABLE
var result = Resources["InfoTableFunctions"].Distinct(params);
Tarun
Hi Aleksandar,
var params = {
Tarun
Thank you !
