How to disable Industrial Gateway log in Thingworx platform from Kepware?
zhuwenxi
There're too many connection warnning/error log from kepware in Thingworx application log. It is not good for application debug.
2 REPLIES 2
slangley
23-Emerald II
(To:zhuwenxi)
Hi @zhuwenxi.
It's probably best to address the cause of the errors instead of suppressing them.  What errors are you seeing?  Which versions of the products are you running?
--Sharon
zhuwenxi
(To:slangley)
We use kepware to connect many telemtry devices. The network is not stable, and sometimes device would be  shutdown when production is done. So many warnning/error would come up in thingworx.
I'm using tw8.5 and kepware 6.5.
