I am not getting idea to display Alerts in Mashups!
Hi Akshay,
The description of your question is not very clear. Do you want to assess alert mashup? You can use URL http://localhost:8088/Thingworx/Runtime/index.html#master=ThingWorxMonitor&mashup=MonitoringAlertSummary
You also can embeded this page to your own mashup by below method:
Add a Contained Mashup widget and bind MonitoringAlertSummary to contained mashup.
If above two solution are not work for you. Please give us some detial informaion about your case.
Best Regards,
Lily
