How to display location data from two columns in a Map ?
done11
I am trying to display two locations in a map , but when I try to bind the second location data in a map it replaces the previous data .
How can I display both of the locations ?
3 REPLIES 3
ttielebein
(To:done11)
You should be able to bind an infotable of locations. You just need an infotable property with a data shape that has one location type field. Then import GetPropertyValues service on your mashup and bind the infotable to the map. Hope this helps!
Hi Tori,
Thanks for your answer . But the problem is that I want to display Point of Interests but it replaces the binding of the current location.Any help ?
ttielebein
(To:done11)
I am not sure I know what you mean by your last comment. Can you elaborate?
