How to dynamically change Title of Master Mashup
Vishnu_K
6-Contributor
Is it possible to update the Title of a Master Mashup dynamically?
Thanks in advance
@CarlesColl
CharlesJi
(To:Vishnu_K)
I think this is not available in ThingWorx for now.
I suggest you can also request it at https://community.ptc.com/t5/ThingWorx-Ideas/idb-p/thingworxideas.
The more votes your request post got, the higher possibility it gets implemented in the future versions.
Hope it helps.
5 REPLIES 5
We have already tired the a solution which was mentioned earlier. link which we followed - https://community.ptc.com/t5/ThingWorx-Developers/how-to-make-make-a-variable-title-for-a-Master-Mashup-in/m-p/587438 This didnt work out when we tried this. @CarlesColl and @vguevaraperez
Vishnu_K
6-Contributor
(To:AC_9903781)
The solution mentioned in the article did not work for me. Can you provide a bit more clarification on that solution? I need the variable to be changed run time.
I don't believe the solution referenced above (using JQuery) will work anymore due to R&D's security concerns with JQuery.  See one of the responses on this article for the specific response:
https://community.ptc.com/t5/ThingWorx-Developers/JQuery-in-mashup-function-ThingWorx-9-1/m-p/715943
Thanks For the Response. Is the any other way to get title Dynamically.
CharlesJi
(To:Vishnu_K)
Hope it helps.
