How to edit data from a grid widget
fmanniti
I've seen that the grid widget has this property that makes a column's data editable.
In my grid I have two columns: NameOfTheThing (string) and View (boolean)
I want View to be editable.
What did I do:
  1. Checked "IsEditable" Property
  2. In Configure Grid Column I checked Editable under the "View" column format
What is my problem:
I don't know how to set the changing runtime.
If I edit my checkbox on the grid I can't actually see my data changing.
PaiChung
22-Sapphire I
(To:fmanniti)
The Grid also has 'Edited Table' that is the full content of the Grid, you need to take that content into a Service to then do the actual data update(s)
Yes, but I didn't understand which service because I tried with Set Properties (which is the service I've used so far to set new values of properties) but it doesn't bind.
Do I have to make my own service?
