Hi, developers!
When I query a huge amount of data from a stream, it usually takes a while.
Is there any chance that I can know the percentage that the event is being done?
1. Query Stream Data
2. Execute
3. Loading
4. (?) Show the loading process
Something like this!!! Thanks!
Sincerely,
Lee
I do not believe that is possible.
As a side note, Streams are only indexed on source and datetime I believe.
So when you query a stream with additional query parameters, those are only applied after the data is in Thingworx.
So if you need a lot of data with analysis, please consider your approach carefully.
