How to edit/update an alert limits from a Service.
biswa
11-Garnet
Hi All,
I want to update the limits of an alert by triggering a service. How can I achieve that?
From Thingworx Support, I got the following code which I have pasted below. I tried running that but it doesnot work.
For example: I have a property "Suction" with basetype as "INTEGER". I have already created an alert for that named "AboveLimit" which will be fired when Suction is above limit 5. Now I want to change the limit through a service. I wrote the following but its not working.
// Create the Attributes Infotable for AddOrUpdateAlert call
var params = {
	infoTableName: "alertAttr" /* STRING */
var attrs = Resources["InfoTableFunctions"].CreateInfoTable(params);
// Define the fields required by an Above type Alert for an INTEGER field (not the values!)
// limit - Minimum value at which the alert will trigger.
var field = new Object();
field.name = "limit";
field.baseType = 'INTEGER';
attrs.AddField(field);
// limitInclusive - Is the condition Greater than (>) or Greater than or equal (>=)?
field.name = "limitInclusive";
field.baseType = 'BOOLEAN';
// Define the new Alert values and add the row to the table.
var row = new Object();
row.limit = 10;			        // Alert will trigger when field >=10
row.limitInclusive = true;		// Alert includes 10
attrs.AddRow(row);
// Call the AddOrUpdateAlert Service
var params = {
	alertType: "Above" /* STRING */,
	alertName: "AboveLimit" /* STRING */,
	property: "Suction" /* STRING */,
	attributes: attrs /* INFOTABLE */,
   	priority: 1 /* INTEGER */,
	persistent: true /* BOOLEAN */,
	enabled: true /* BOOLEAN */
me.AddOrUpdateAlert(params);
 Please help to achieve the following!!!
Thanks in advance.
PaiChung
22-Sapphire I
(To:biswa)
Composer you just need to do a Save/Cancel/Edit type action to refresh the Thing, it caches the info and a programmatic change will not force the refresh, Save/Cancel/Edit will force a reload from the entity storage.
The RestartThing will do exactly that, which means that non-persistent properties will reset to default, if there is a system action involving that Thing while it is being restarted, it will fail (time to restart should in general be very short millisecond(s)
8 REPLIES 8
PaiChung
22-Sapphire I
(To:biswa)
Have you tried adding a RestartThing() after you updated the Alert?
biswa
11-Garnet
(To:PaiChung)
No its not working. Is there any other way I can change the "Limit" of an alert from a service?
PaiChung
22-Sapphire I
(To:biswa)
If the code is working correctly then the only other way would probably be to first remove the alert and then add your new one.
biswa
11-Garnet
(To:PaiChung)
Seems like now its working. But I noticed one thing that its not working immediately. I have to logout of the composer and then login again or refresh the composer again to see the change. Is there any way I can avoid this? And also I had another doubt. Actually I am making a digital twin of a oil and gas plant. Does using RestartThing() effect the functioning of any component of the plant!!!
PaiChung
22-Sapphire I
(To:biswa)
biswa
11-Garnet
(To:PaiChung)
Thanks for the information.
Just one last thing, the services that I have written for creating an alert works but the problem is it gets reflected only after I logout and login again. Is there any way I can see those created alerts as soon as the service run is completed without logging out and logging in again?
PaiChung
22-Sapphire I
(To:biswa)
This didn't work for you?
"Composer you just need to do a Save/Cancel/Edit type action to refresh the Thing, it caches the info and a programmatic change will not force the refresh, Save/Cancel/Edit will force a reload from the entity storage."
biswa
11-Garnet
(To:PaiChung)
I guess its working now. Thanks a lot.
