How to embed the mashup directly from the front-end, bypassing the login info without exposing key
YF_9574894
6-Contributor
Hi everyone
    My application scenario is that the mashup application is directly accessed through the micro application, and there is no user login during this process. How do I need to achieve this?
Requirements: The access connection cannot expose Appkey and user information.
Do I need to use Authenticator to realize the function?
Has anyone implemented it or has a similar case there?
Please let me know if you know
Thank you so much and have a great life
@YF_9574894 ,
If you want a scenario where a user does not have to log in to ThingWorx or expose an application key, I would suggest using Single Sign-on if that is something that your team uses.  If you do not use SSO, you may need to craft some custom Authenticator to meet your specific need.
- Nick
