How to enable sorting for all fields in grid widget
Willie
In TWX 8.5, it was possible to enable sorting for all fields in advanced grid widget without enabling it for each field. In TWX 9.5, the new grid widget requires the sort functionality to be enabled individually for each field in grid configuration. Is there a way to make all fields sortable without enabling it individually for each field in grid configuration?
Rocko
18-Opal
(To:Willie)
If you want a hack:
-Export
-Edit XML
-Find/Replace "editable" : false,  --> "editable" : true,
-Reimport
Otherwise no.
