How to enter the value in list/dropdown manually at runtime and also pass entered value to service?
Sheetal_sable
hi,
My requirement is..for eg. I want to display a list of years from 2017-2030, so for this i have written as service and bind it to list widget. so i will get a list of years in dropdown/combobox. But what if a user wants a year 2016  data, but the year not present in list. I want a option in dropdown/combobox to enter the year manually also. so that i get the data of that year too.
Is there any way of doing it?
Sheetal
3 REPLIES 3
Current OOTB widgets don't have that.
You can do a create your list, and then append an entry, "Enter new" which then provides a Text Box or Numeric Entry for the user. This does mean your initial values have to be String.
Or otherwise it would be a custom widget creation as an extension.
Hi @PaiChung  ,
Thanks for reply.
You said,  create your list, and then append !!.. Please tell me the steps.
Or can create a custom widget extension.   I have not tried custom widget before. How can i do that?
sheetal
When you retrieve the choices you'll have an infotable with rows.
You can then create a new 'row object' using the infotable services, add your information and do an 'addRow'
I'm not knowledgeable on extensions unfortunately.
