How to execute OData WRS from thingworx composer ?
Am able to execute through postman.
I tried to execute similar to swagger in thingworx composer, but unable to succeed it.
I try to do the same but I don't know how to execute ODATA WRS from the composer either.
Did you finally got it working?
Hi.
I would be interested too.
Sébastien
I think your question is about setting up OData connector thing in Thingworx and fetching data from windchill using rest end points .For setting up and configuring the connection you can follow this article :
https://www.ptc.com/en/support/article?n=CS291231
Hope it helps!
Thanks ,
Mukul Narang
