How to execute PDF Extension in Thingworx?
Level 8
I am using Thingworx  Navigate  1.8 and Platform 8.3.
I am able to import PDF Extension in TW composer.
But while uploading it gives warning as ,
            "           Export file missing version information.  No migration will be performed.    "
When I try to execute " create PDF " service from PDF Export , in Application log i found '
            "              Could not start process:     "
I have installed java 8u144 version.
Re: How to execute PDF Extension in Thingworx?
It may need a newer version of java. If you upload to Java 8u191 does it work ?
thanks,
Ciprian
Hi @shindemayur.
If you found a solution to your problem, please feel free to post it here and mark it as the Accepted Solution.  This will help others who may have the same issue.
--Sharon
