The community will undergo maintenance on October 16th at 10:00 PM PDT and will be unavailable for up to one hour.
Hi Experts,
I want to create a UI widget using standard widgets code. Please let me know where I can find the JS code of OOTB widgets like Pie chart ,Button, etc. ?
I tried looking into the installation path of the Thingworx as well as storage path but no luck.
Thingworx version in use is 9.3.
1. There was a similar question before - "Any way to view code for OOTB widgets?": https://community.ptc.com/t5/ThingWorx-Developers/Any-way-to-view-code-for-OOTB-widgets/td-p/508612
2. GitHub - "ThingWorx Demo Webpack Widget": https://github.com/ptc-iot-sharing/ThingworxDemoWebpackWidget
I checked the above path/link but couldn't find OOTB widgets code. I can see only a SVG file there.
Is the location of it is different in case of Thingworx version?
I am on Thingworx 9.3.
Hey even I am struck here. Found any relevant solution?
Also see the following comment: https://community.ptc.com/t5/ThingWorx-Developers/Any-way-to-view-code-for-OOTB-widgets/m-p/508614/h...
