You may not be able to login to the Community at the moment. We are working on a solution. We apologize for the inconvenience.
I want Onscreen Keyboard functionality to be enabled for textbox widget. Is there any extension for this??
Hi Bavithraa Marimuthu,
As far as I know, there is no such widget or extension ready-to-use. One option would be to custom it as an extension on your own.
And, as an alternative, you could add some buttons in your mashup to imitate the keyboard and pass different values to the textbox(You need append the new chosen character behind the one in the textbox which is chosen the last time).
For example:
Hope this helps,
Br,
Anna
Such extension is not available currently in Core ThingWorx and also on Marketplace. You will have to create your own custom extension for this feature.
