The community will undergo maintenance on October 16th at 10:00 PM PDT and will be unavailable for up to one hour.
Hello team,
I use a menu widget and I want selected menu name on label/header
how can i get this?
Gaurish
What are you using it for?
Depending on how the menu is set (Drive Parameter), you can bind the selection to another Widget/Parameter
