How to get and send data to Integrity from ThingWorx
priyag3
Read and send data to Integrity using webservice from ThingWorx
1 ACCEPTED SOLUTION
slangley
23-Emerald II
(To:slangley)
Hi @priyag3.
From further research it appears there is an extension for the ThingWorx version you are running.  However, it may require additional entitlements.
Please check the documentation available here.  You will need to confirm the product requirements detailed on page 12.
The extension is available on the support site (refer to the image below to locate it).  If you do not see this software under your login credentials, you will need to check with your Sales Rep to obtain an entitlement.
Regards.
--Sharon
5 REPLIES 5
slangley
23-Emerald II
(To:priyag3)
Hi @priyag3.
Please check out this page in our Help Center to see if it answers your questions.
Regards.
--Sharon
slangley
23-Emerald II
(To:slangley)
Hi @priyag3.
If the previous response answered your question, please mark it as the Accepted Solution for the benefit of others with the same question.
Regards.
--Sharon
priyag3
(To:slangley)
The solution can work in ThingWorx 8.4 but I am using ThingWorx 7.4.
slangley
23-Emerald II
(To:slangley)
Hi @priyag3.
Regards.
--Sharon
priyag3
(To:slangley)
@slangley I am using the extension. Thanks
