How to get credentials from Azure Key Vault via ThingWorx
Janaki.Raman
help required to  retrieve credentials from Azure Vault to thingworx, this will later be used to in Thingworx configurations.
please help.
Janakiraman
I wouldn't do this from ThingWorx if I were you. Cloud compute workloads rarely access secrets directly, and instead they expect to be configured from the outside. So I would instead create an Azure Function, which would access those secrets and inject them into your running ThingWorx instance via REST. You can then trigger that function manually or from your CI/CD pipeline.
/ Constantine
Vilia (my company) | GitHub | LinkedIn
/ Constantine
Hello @Janaki.Raman,
It looks like you have some responses from some community experts. If any of these replies helped you solve your question please mark the appropriate reply as the Accepted Solution.
Vivek N.
Community Moderation Team.
