How to get data from Azure SQl using thingworx database thing
Janaki.Raman
11-Garnet
Hello All,
I have plant information stored in Azure sql database, i need help to connect to that database and query data from that.
thanks,
Janakiraman
Hi @Janaki.Raman,  look at the article below and let us know if you have any doubts.
https://www.ptc.com/en/support/article/CS226762
2 REPLIES 2
Hello @Janaki.Raman,
I wanted to follow up with you on your post to see if your question has been answered.
If so, please mark the appropriate reply as the Accepted Solution for the benefit of other members who may have the same question.
Of course, if you have more to share on your issue, please let the Community know so that we can continue to support.
Abhiraj
