Community email notifications are disrupted. While we are working to resolve, please check on your favorite boards regularly to keep up with your conversations and new topics.
Please help on following ,
I want to get date field from CSV file. If I apply dataShape (Date column as Datetime). will getting error (tried many ways, still didn't get answer).
let params = {
path: "/PhysicalTestMachineData.csv" /* STRING {"defaultValue":"/"} */,
columnMappings: undefined /* STRING */,
hasHeader: true /* BOOLEAN {"defaultValue":false} */,
longitudeField: undefined /* NUMBER */,
dateFormat: parseDate(Date, "DD/MM/YYYY") /* STRING */,
fileRepository: "SystemRepository" /* THINGNAME */,
latitudeField: undefined /* NUMBER */,
fieldDelimiter: "," /* STRING {"defaultValue":","} */,
stringDelimiter: undefined /* STRING {"defaultValue":"\""} */,
customFieldNames: undefined /* STRING */,
dataShape: "Physical_E1" /* DATASHAPENAME */
// result: INFOTABLE
let result = Resources["Parsley"].ParseCSV(params);
Error executing service GetPhysicalTest_CSV_1. Message :: Invalid format: "org.mozilla.javascript.IdFunctio..." - See Script Error Log for more details.
Thank you
I know this solution isn't ideal, but you can add an extra text field to your datashape to accept the string value of the date, and then use the:
var newDate = new Date(dateString);
to get it to the format you need for your DateTime column.
Hope that helps
- Nick
You didn't provide sample data or the datashape, plus Parsley is not a PTC-supported extension, so you might get better advice asking the developer. I've seen him around here @jamesm1
The images at https://github.com/jmccuen/parsley seem to be broken as well which leaves us with little information, but from what I can see, wouldn't you just use the plain date format in the parameter?, e.g.
dateFormat: "DD/MM/YYYY",
EDIT: What's probably also to know is that you have to use joda time format for your format string. See https://www.joda.org/joda-time/apidocs/org/joda/time/format/DateTimeFormat.html
Try dd/MM/yyyy
