Hi all,
I have a requirement where there are 2 fields of an infotable say data1 (basetype infotable) and data2(basetype infotable).
Now I need to create an infotable which is as such data1-data2
That is the elements of data2 must be subtracted from data1 and the result must be in answer.
How to achieve it?
You should do something like this:
var result = Resources["InfoTableFunctions"].DeriveFields({
t: myInfotable,
types: "LONG",
columns: "differenceInMilliseconds",
expressions: "dateDifference(data1,data2);"
Hi, keep in mind that datetime is calculated in milliseconds, so you can use that for your math logic and then output the result in the datetime format again.
t: myInfotable,
types: "LONG",
Thanks a ton! It worked
