How to get difference between fields of an infotable which are of date time basetype and the solution is also of datetime base type
vsrilekha
Hi all,
              I have a requirement where there are 2 fields of an infotable say data1 (basetype infotable) and data2(basetype infotable).
Now I need to create an infotable which is as such data1-data2
That is the elements of data2 must be subtracted from data1 and the result must be in answer.
How to achieve it?
You should do something like this:
var result = Resources["InfoTableFunctions"].DeriveFields({
  t: myInfotable,
  types: "LONG",
    columns: "differenceInMilliseconds",
  expressions: "dateDifference(data1,data2);"
posipova
20-Turquoise
(To:vsrilekha)
Hi, keep in mind that datetime is calculated in milliseconds, so you can use that for your math logic and then output the result in the datetime format again.
  t: myInfotable,
  types: "LONG",
Thanks a ton! It worked
