I have a thing whose property values are repeated. How to get distinct values from this property values? some thing like sql query SELECT distinct(propertyname) from table.
Azim
Hi Azim are you trying to get distinct value from Infotable? There's an existing DISTINCT script available something like this
var params = {
t: undefined /* INFOTABLE */,
columns: undefined /* STRING */
// result: INFOTABLE
var result = Resources["InfoTableFunctions"].Distinct(params);
Hello Sushant,
Is there any service which can return me this distinct values?
Azim
Are you looking for Infotable?
Hi Sushant Pandey,
Since there could be one or more distinct values then it would be an info table.
Azim
It should be Distinct as you can see under the ThingWorx Composer > System > Resources > InfoTableFunctions > Distinct
Could you please tell me how can I achieve the same using java?
Azim
Can a service return distinct values? If no can you please tell me java equivalent of below code.
var params = {
Did you test out this service? Is it not returning what you are looking for?
Hi Sushant Pandey,
I could not test this. I do not know how can I execute this service in Java.
Azim
