How to get distinct values of properties?
ahawaldar
1-Newbie
I have a thing whose property values are repeated. How to get distinct values from this property values? some thing like sql query SELECT distinct(propertyname) from table.
Azim
9 REPLIES 9
supandey
(To:ahawaldar)
Hi Azim are you trying to get distinct value from Infotable? There's an existing DISTINCT script available something like this
var params = {
t: undefined /* INFOTABLE */,
columns: undefined /* STRING */
// result: INFOTABLE
var result = Resources["InfoTableFunctions"].Distinct(params);
Hello Sushant,
Is there any service which can return me this distinct values?
Azim
supandey
(To:ahawaldar)
Are you looking for Infotable?
Hi Sushant Pandey​,
Since there could be one or more distinct values then it would be an info table.
Azim
supandey
(To:ahawaldar)
It should be Distinct as you can see under the ThingWorx Composer > System > Resources > InfoTableFunctions > Distinct
Could you please tell me how can I achieve the same using java?
Azim
Can a service return distinct values? If no can you please tell me java equivalent of below code.
var params = {
supandey
(To:ahawaldar)
Did you test out this service? Is it not returning what you are looking for?
Hi Sushant Pandey​,
I could not test this. I do not know how can I execute this service in Java.
Azim
