Is it possible to determine what a entity is?
I will explain myself:
I would like to make a service which has both as input and output a string.
I insert the name of a entity and it returns
"This entity is a Thing"
"This entity is a Data shape"
"This entity is a username"
Is this possible?
Hi Fabio,
Here is the solution for your question.
Hope it helps!
Andy
Thank you!
That's my method
function getEntityDescription(myEntityName) {
var collectionName = 'Things';
var entityType ='Thing';
var isThing = true;
var isThingTemplate = false;
var isThingShape = false;
var isDataShape = false;
var isModelTag = false;
var isNetwork = false;
var isDataTag = false;
var isOrganization = false;
var entity = Things[myEntityName];
if (entity==null) {
isThing = false;
entity = ThingTemplates[myEntityName];
isThingTemplate=true;
collectionName = 'ThingTemplates';
entityType = 'ThingTemplate';
if (entity==null) {
isThingTemplate=false;
entity = ThingShapes[myEntityName];
isThingShape = true;
collectionName = 'ThingShapes';
entityType = 'ThingShape';
if (entity==null) {
isThingShape=false;
entity = DataShapes[myEntityName];
isDataShape = true;
collectionName = 'DataShapes';
entityType = 'DataShape';
if (entity==null) {
isDataShape=false;
entity = ModelTags[myEntityName];
isModelTag = true;
collectionName = 'ModelTags';
entityType = 'ModelTagVocabulary';
if (entity==null) {
isModelTag=false;
entity = Networks[myEntityName];
isNetwork = true;
collectionName = 'Networks';
entityType = 'Network';
if (entity==null) {
isNetwork=false;
entity = DataTags[myEntityName];
isDataTag = true;
collectionName = 'DataTags';
entityType = 'DataTagVocabulary';
if (entity==null) {
isDataTags=false;
entity = Organizations[myEntityName];
isOrganization = true;
collectionName = 'Organizations';
entityType = 'Organitzation';
return {
entity: entity,
isThingShape: isThingShape,
isThing: isThing,
isThingTemplate: isThingTemplate,
isDataShape: isDataShape,
isModelTag: isModelTag,
isNetwork: isNetwork,
isDataTag: isDataTag,
isOrganization: isOrganization,
collectionName: collectionName,
type: entityType
Would be good to know which method it's faster...
Ok I did some tests,
Iterating 1000 times over both functions, my method last at max 10ms ( for 1000 iterations ), the SearchModelEntities method lasts for 15000ms ...
Oh, that's a great point.
Even because your method was quite similar to mine.
I have this input which can be Username, Thing, ThingTemplate.
My metod was
var isUser = (Users[myInput]) ? true : false;
var isThing = (Things[myInput]) ? true : false;
var isTemplate = (ThingTemplates[myInput]) ? true : false;
so, tecnically, it's even faster since it has to choose between three.
I just asked because I believed it was not too orthodox
Your are good to go with you method.
With Search method you must use Search resources, with ModelEntityCollection[] method you are working with In-Memory objects, that's why it's a way faster.
One second, your solution Fabio has a problem, look at my General Performance Recommendations and some perks (unofficial) document.
You should check always explicit --> (Users[myInput])? true : false; should be (Users[myInput]!==null)
and so on.
Oh, ok. Thanks!
