How to get maxItems dynamically to use in SearchThingsByTemplate method
aksharma2911
I am using below code to get all things data .
var params = {
maxItems: 700000,
nameMask: undefined,
query: undefined,
thingTemplate: 'tempalteName',
tags: 'tagname'
var result = Resources["SearchFunctions"].SearchThingsByTemplate(params);
Instead of 700000 as hardcoding. is there any function which will give me available thing count which implemented the said thing template.
Hi @aksharma2911 you could look into using GetImplementingThings() , see the API doc for more
You should look onto services performance, they vary a lot between them, maybe instead of using the total of the specific derived ThingTemplate it's ok with just giving the total of things ( which it's available at no processing power cost ):
You have the service:
var entityCount = Subsystems["PlatformSubsystem"].GetEntityCount({ type: "Things" });
Where you get the total number of things.
