I am writing a simple service to obtain a property, (Temperature, Humidity..etc) from a Thing. I have an InfoTable listing all the Thing properties but I want to grab the numerical value of a pre-specified property. I need some help in the last line to grab the value from the infotable obtained from GetPropertyValues.
if (thingName) {
var t = Things[thingName];
table = t.GetPropertyValues();
// obtain temperature value from table
// result = table.value(property);
Daniel
Hi Daniel,
Any reason why you want to use the getProperties? You can do it by doing:
result = table.YOURPROPERTYNAME;
You can also use indirect reference:
result = Things[thingName].YOURPROPERTYNAME;
Cheers
Ewerton
Hi Daniel,
Cheers
Ewerton
