How to get the field value of a field from a row of InfoTable
ptc-1849353
6-Contributor
I have a InfoTable with 4 fields in it. There are 3 rows in my InfoTable. I want to get the value of 1st field of second row.
I am able to get the second row now out of this row i want get 1st field value and feed it to some LED widget.
Please let me know if it is possible.
Thanks in advance!!
Mohammed
2 REPLIES 2
Mohammed,
You can access the first field's value using dot notation. For example: result = myInfoTable[1].fieldName
I assume you're guaranteeing the order in which entries come back by sorting or similar? Otherwise, how do you know you'll always want the second row?
– Adam
paic
(To:ptc-1849353)
<p>To follow up on what Adam wrote:<p></p><div><p class="MsoNormal"><span style="font-family:&quot;Verdana&quot;,sans-serif">Usually there
is no guarantee what order columns/fields are in.<o:p></o:p></span></p>
<p class="MsoNormal"><span style="font-family:&quot;Verdana&quot;,sans-serif">So it is best
to refer to it directly<o:p></o:p></span></p>
<p class="MsoNormal"><span style="font-family:&quot;Verdana&quot;,sans-serif">Like
infotablevar.rows.FieldName<o:p></o:p></span></p>
<p class="MsoNormal"><span style="font-family:&quot;Verdana&quot;,sans-serif">Else<o:p></o:p></span></p>
<p class="MsoNormal"><span style="font-family:&quot;Verdana&quot;,sans-serif">Otherwise,
you can treat the infotable as a json object...<br>
for (var el in infotable.rows) {<o:p></o:p></span></p>
  console.log("Element name: " + el + ", element
value:" + infotable[el] + ", element type: " +
typeof(infotable[el]));<o:p></o:p></span></p>
<p class="MsoNormal"><span style="font-family:&quot;Verdana&quot;,sans-serif">}<o:p></o:p></span></p></div></p>
