How to get the text displayed in label from Database only if the button is enabled?
bmarimuthu-2
  See  even " run comm tests " is disabled ,  I am getting text in system message.
How to get  the text displayed in label from Database only if the "Run communication Test" is enabled?
Bavithraa Marimuthu​,
You must be using some boolean input to disable the Run Communication Tests button.
Just create a custom service which takes boolean input parameter (same that disables Run Communication Tests button) and returns result only when boolean value is false else empty result( when true).
I hope it helps.
