How to give the image for widget to identify it in mashup builder while creating extension
SaiSameera
Hi, I'm creating a widget through eclipse. I want to know where the image should be given for the widget to identify it in mashup builder while creating extension.
supandey
(To:SaiSameera)
Hi @SaiSameera you'd need a image included for it something like this
TW.IDE.Widgets.mywidget = function () {
this.widgetIconUrl = function() {
return "../Common/extensions/MyExtension/ui/" +
"mywidget/mywidget.ide.png";
See Adding Custom Widget in the attached documentation on page 41
Note: Image used in widget icon needs to be 16 by 16 pixels
Leigh
Emeritus
(To:supandey)
Hi @SaiSameera
Just wanted to follow up to see if Sushant was able to answer your questions.  If so, please indicate his response as an Accepted Solution for the benefit of the rest of the Community.  If not, please let us know your current status.
Thanks!
Leigh
