I'm unable to view the the widgets in mashup builder after importing the widget. The widgets are visible in the Thingworx Storage->extensions but not in the mashup.
Hi @SaiSameera could you please specify which one of those extensions aren't getting listed in the Widgets list? Can you share if there was any issue in draging and dropping them on the Mashup?
Thank you. Now I'm able to view the widget on mashup builder. The problem is the widget extension that I've created is not build properly.
Hi @SaiSameera
It appears that you have resolved your issue. For the benefit of others in the Community, can you indicate your response as the Accepted Solution? If you continue to have an issue around this, please let us know your current status.
Thanks!
Leigh
