How to give visibility access in mashup?
nbhagtani
I have 3 types of user and one mashup.
I have made 3 type of usergroups and added users to those groups. Also created organization and added all 3 user groups to that organization.
All 3 users should be able to see different or relevant parts(for that particular user) on same mashup.
How i can achieve this?
nkhose
(To:nbhagtani)
Hi ,
You can give design time and runtime permission to set of user roles  , additionally there is a provision for service overides for particular User.
I think you have requirement to show the html pieces for set of user roles , you can make custom services add in mashup , use expression widget
to visible True or False .
eg
var result = Resources["CurrentSessionInfo"].GetCurrentUserOrganizations();
var result = Resources["CurrentSessionInfo"].GetCurrentUserGroups();
Some of snippets , you can look for Resources methods for Currently logged user .
Check below
Levels of access for members
posipova
20-Turquoise
(To:nbhagtani)
In addition, please refer to the following video on more information regarding permissions and "deny all" default policy, https://www.youtube.com/watch?v=HzFqxvgHtpI&index=8&list=PLz1ppcU_kaneagUT9qgQfz3HByf6-9zTF
You may also look at this document on the use of system user The use of System User
