How to hide the header of grid? ths
Hi Cyril,
I've tried to hide the header in the default Grid Widget as well as the Advanced Grid Widget from the ThingWorx Marketplace.
For both widgets I couldn't hide the header directly. However I changed the .css for the Advanced Grid and removed the table row with a "display: none" style
<tr style="display: none;">
However this needs to be manipulated manually and is not an out of the box feature.
Not sure if that works for you...
Cheers,
Michael
I've opened an enhancement request for R&D to check with Product Management if a "hide headers" option can be introduced in one of the future releases of the Grid Widget (PSPT-3768).
There is no option to remove/hide the header; however, you may look into editing the widget /developing your own solution. The grid widget is located in <tomcat install location>\webapps\Thingworx\common\thingworx\widgets\
