We have the DataTables defined in our application.And the applcation is imported as thingworx-extension. We need the dataTable to have default data rows i.e. some entries prepopulated.
Is it possible to export and import data as xml (seems only binary is suuported)? Is there any other way to load data to Datatables through extension
I am also looking for a solution. I am thinking of having JSON/CSV/XML file within my extension which I can read and populate as data in Data table. I am wondering how do I call this once after installing my extension. Any thoughts??
You could consider having a script with embedded JSON inside a ServiceHelper script and run that.
I have do this a few times- Having an additional import can often get missed and have a script that initializes can be quite helpful.
Snippet example - example
var table = Resources["InfoTableFunctions"].CreateInfoTableFromDataShape(params);
table.AddRow({ "startCount":1500, "createCount":1, "thingName":"BOX1", "model":"XBOX1", "make":"MS","family":"MICS", "dealer":"DC01", "customer":"CUST01", "device":"PLG01", "SerialNumber":"1000000", "Identifier":"I000000","groupName":"MGROUP", "groupPrivate":true});
table.AddRow({ "startCount":15100, "createCount":2, "thingName":"BOX2", "model":"XBOX2", "make":"MS","family":"MICS", "dealer":"DC01", "customer":"CUST01", "device":"PLG01", "SerialNumber":"1000000", "Identifier":"I000000","groupName":"MGROUP", "groupPrivate":true});
table.AddRow({ "startCount":15200, "createCount":3, "thingName":"BOX3", "model":"XBOX3", "make":"MS","family":"MICS", "dealer":"DC01", "customer":"CUST01", "device":"PLG01", "SerialNumber":"1000000", "Identifier":"I000000","groupName":"MGROUP", "groupPrivate":false});
Thanks Steve. It makes sense. How do I automatically trigger my service to load the data?
Varathan
Good question,
I would consider creating a Checker Mashup that could be run by Admin after importing and used to check the state of the import etc and inside that is a HelperService to check and decide if the Database has been loaded or even provide a Button to execute the service.(adding are you sure :-) ) Might seem a little over kill but an Administrator would probably appreciate a Checkup setup.
Or you could just add it to the Main Mashup and check on Mashup Loaded - but that would always be executing and seems overkill and redundant after first time run.
I am thinking of adding a Boolean property which by default false. On Thing Start of my Data Table subscription, I will check whether my count matches or other validation. If not I can load the data. Then I can set the flag to true. From next time onwards, the flag will be true so my code will skip the entire piece of loading logic.
I am going to see whether I can disable Subscription from its own code. That way the need for the flag can be eliminated.
Varathan
