How to inherit a custom widget properties on an infotable
Hemanth
I have created an custom widget for sorting the table columns (I have used DevExtreme jQuery code  for sorting and added dummy data for the table) using eclipse and I have imported the widget successfully in thingworx 8.5 and it is working. I want to add those widget (sorting the column) properties to the Infotable data which I am getting from a service. When I drag and drop the widget to the mashup and add service and bind the All Data to the widget data property, the Infotable data columns should have the sorting properties of the widget.
How can this be done?? Any detailed document/steps to be followed will help in overcoming this issue??
slangley
(To:Hemanth)
Hi @hm_10042491.
There is functionality in the core product that provides sorting capabilities.  This page from the Help Center provides more information. The Sorting Options section on this page may also be helpful.
--Sharon
