How to link a menu to contained mashup so that when we select a menu item it opens a corresponding mashup in contained mashup.
psaxena
As an when we select an item in a menu the corresponding mashup should open as contained mashup.
2 REPLIES 2
Hi Priyanshi, you will have to bind "Mashup" field in Menu to "Name" in contained mashup.
PaiChung
22-Sapphire I
(To:psaxena)
If you put the Menu in the Master, it will automatically know the contained space to update.
If you put it in a mashup, then you need to use the Menu in 'drive mashup parameter' mode and set that to the contained mashup space of choice.
