My Customer are implementing to store event driven data using Valuestream.
The log data stored in value stream for a period of time and log data isn't storing in value stream after certain time(2~3 days)
Does Value stream have limitation of data size?
Could you help me to fix this issue?
Hi Carles~~
I read the post you shared.
Main issue of my customer is that log data is no longer being stored in the valuestream two or three days after.
My customer and I guess that valuestream has limitation of data size.
Could you help me to fix this issue.....?
Regards
Yongjune.
Hi Yongjune,
If it stopped to store on the ValueStream, it seems another problem, the Thing it's running? how many data it's on the ValueStream for the property? there's space on disk?...
Carles.
This needs a lot more information and I recommend submitting a case with support.ptc.com
