var params = {
url:"file://C:/Users/ShaurabhKumar/Documents/MATLAB/AGENT.xml",
timeout:160
Got Error:
Wrapped org.apache.http.client.ClientProtocolException Cause: null
I am trying to read an xml file on my system.
Is there any other way to do the same?
Thank you
Uploaded file would only be a snapshot.
if you have something that is updating the XML file continuously, if you can, you could post the incremental updates to Thingworx using either the Edge MicroServer or the REST API
Not sure if that is possible, could be a variety of reasons, I recommend you create a mashup and do an upload of the file to a repository and process it from there.
Yes I believe that would be one way of doing it. But what if the xml file keeps updating with time(real time data). If i store it in the repository would it simply store a version of it?
Hi Pai,
Since i am new to this, Could you please guide me towards a tutorial perhaps or some sort of help for implementing REST API in thingworx? Since i need to read an xml from my system through the service javascript. or perhaps you could guide me through the steps.
Thank you
Thingworx Fundamentals has a section on this.
