Example
A(G) | B (G) | C (G) |
0.007297 | 1.04E-05 | 3.00E-06 |
0.007924 | 6.86E-06 | 2.10E-05 |
This is CSV data example.
If i make loader. Can Thingworx handle it?
if not i will make translate data like this.
1.04E-05 --> 0.0000104.
how to do this case?
Hi @jaiminLee
ThingWorx, using the CSVParser, will be able to read the values.
I did a quick test and here is the result:
CSV file:
A | B | C |
Result in AdvancedGrid widget:
Same code as in this post has been used to load the csv.
Hope this helps
Christophe
