How to make a layout column scrollable?
muzzammil
How do i make the Layout portion scrollable?
I mean.., lets say i create a mashup. On which i put a layout of 2 columns. On the left column, i put a map widget which should not be scrollable. On the right column, i put some 2 tabs. And under each tab i wish to have some 24 time series charts in 12x2 pattern. So, i wish to make the right column scrollable. How do i achieve this?
PaiChung
22-Sapphire I
(To:muzzammil)
you can use a collection widget as one approach which I recommend.
The other way would be to first add a panel into that area to make it non-responsive
PaiChung
22-Sapphire I
(To:muzzammil)
muzzammil
(To:PaiChung)
@PaiChung could u pls elaborate ur saying?
slangley
(To:muzzammil)
Hi @muzzammil.
Not sure what aspect of Pai's statement requires elaboration, but you can learn more about the collection widget here and here.
The panel widget can be used to make an area of a responsive layout non-responsive.  Responsive widgets auto-rotate and auto-scale.  Non-responsive widgets are fixed.
Please let us know if you have further questions.
Regards.
--Sharon
slangley
(To:slangley)
Hi @muzzammil.
If one of the previous responses answered your question, please mark the appropriate one as the Accepted Solution.  If you still have questions, please elaborate on the issue you are experiencing so we can try to assist.
Regards.
--Sharon
