When is the isConnected property in the remote thing will update?
Is it the time websocket connection established or it will update when data reaches the data from sdk or based on the alwaysOn protocol which will keep on updated by the pings?
-thanks,
Abhiram
In general, after the connection is made to the platform AND the Thing is bound. If a connection is made, but the Thing is not bound, the property will not be updated.
Hi @Abhiram.
If the response from @thingw0rxgenie answered your question, please mark it as the Accepted Solution for the benefit of others with the same question.
Regards.
--Sharon
